Clutch Pedal Adjustment
JB052
When I look at the clutch pedal on our 2006 Aygo it sits a lot higher than the other pedals so I suspect it needs adjustment.
Can anyone tell me how this is done, I have had a look through some of the previous posts but they seem to be more about clutch failure which I'm trying to avoid.
Cheers...John
there is only a very small adjustment of the clutches, it wont make a massive difference. Toyota have changed the parts over the years so if you buy a clutch kit aftermarket it will be the original spec which will go the same way
alex
