D4D Cheak Engine Light
gerry68
hi all
im a new member ,
i bought an 2004 2.ol d4d avensis last week ,on the way home the cheak engine light came on :disgust:
i looked it up and the most common fault listed was the egr valve sticking
so i cleaned it up and the same problem came up .code was p0400
i got a second hand unit same problem came up so i just bought a new one .
even with the new valve the same problem came up :dontgetit:
i took the first valve off and cheaked the air flow coming from the exhaust and the vacuum going into the inlet and neither where not blocked ?
so im thinking either the stainless steel gasket has a problem or the sensor picking up the gas flow into the engine is a fault .
any help would be greatly apperciated thankyou .
Got it sorted
The air intake manifold was stuffed up with carbon soot .
Took it off and cleaned it out .
Alls fine now
glad to hear all is well now. silly question, i have a 2006 car, where is the obd II port? thanks
Sat in the drivers seat it's just below your right knee and it has a little plastic cover on it which just pulls off.
Pete.
Yup
Just up above the space between the throttle and brake pedal .
Mine was a bit fiddley the connect it so be gentle
can someone recommend me a easy to use to obd II reader, i want it to work on avensis 2004 vectra 2005 , octavia.
have a look on Fleabay m8 and if you have a fruit based phone theres even wireless ones that work with an app on your phone :ph34r:
I have there's that many I don't know which one to use lol
if your just looking to read codes and reset mil lights then cheap & cheerful, about a £10
Marty
