jonny__g 1 Posted December 13, 2012 Share Posted December 13, 2012 hi alli think im in need of a new Battery and cant seem to find out what the OEM spec are for my car in terms of aH, cold crank etc.it's a 2004 2.0 D4D corolla T3.ThanksJ Quote Link to post Share on other sites
Cyker 388 Posted December 14, 2012 Share Posted December 14, 2012 IIRC the cold crank amps needs to be at least 550A and capacity, 70Ah or better. obv higher the better for both tho' ;) Quote Link to post Share on other sites
avensisd4d786 250 Posted December 14, 2012 Share Posted December 14, 2012 hi alli think im in need of a new battery and cant seem to find out what the OEM spec are for my car in terms of aH, cold crank etc.it's a 2004 2.0 D4D corolla T3.ThanksJput your reg into www.eurocarparts.com or even Halfords website and they will tell you which battery's are available for your model.I got mine from andrew page, Bosch 65 inc vat with 4 year guarantee, if your buying from a motor factors they should be able to advise you from your reg. Quote Link to post Share on other sites
avensisd4d786 250 Posted December 14, 2012 Share Posted December 14, 2012 hi alli think im in need of a new battery and cant seem to find out what the OEM spec are for my car in terms of aH, cold crank etc.it's a 2004 2.0 D4D corolla T3.ThanksJput your reg into www.eurocarparts.com or even Halfords website and they will tell you which battery's are available for your model.I got mine from andrew page, Bosch 65 inc vat with 4 year guarantee, if your buying from a motor they should be able to advise you from your reg. Quote Link to post Share on other sites
oldcodger 351 Posted December 14, 2012 Share Posted December 14, 2012 Hi,As mentioned above the motor factors such as ECP,GSM or Pages usually have much better deals on batteries.Its often said with an older car to get the next higher amperage Battery.However before you buy any, make sure it will physically fit your Battery shelf and bracket.I got a Bosch from ECP but had to refashion the bracket to make it fit.Be aware that disconnecting the Battery may put you engine into ' learning' mode again - and you may find things like tickover are very high until it 'learns'If you have or can rig up a 'Battery saver' before you take out the main Battery you will avoid that problem. Quote Link to post Share on other sites
jonny__g 1 Posted December 14, 2012 Author Share Posted December 14, 2012 cheers for all the info. the Battery that's in at the moment has just the SAE 690amps and reserve capacity time 135 mins. it's a 'Yuasa' brand. is this OEM stock brand? Plus, is the SAE same as cold crank ampage or what is it?thanks Quote Link to post Share on other sites
jonny__g 1 Posted December 14, 2012 Author Share Posted December 14, 2012 Have reserved this one at euro car parts. will get extra 15% off with voucher code battery15 for anyone else interested! opinions?http://www.eurocarparts.com/ecp/c/Toyota_Corolla_2.0_2004/p/car-parts/car-electrics-and-car-lighting/electrical/car-battery/?444771000&1&06fbc3159c6d1128115ddf016f1d8a1acac380d2&000020 Quote Link to post Share on other sites
avensisd4d786 250 Posted December 14, 2012 Share Posted December 14, 2012 Have reserved this one at euro car parts. will get extra 15% off with voucher code battery15 for anyone else interested! opinions?http://www.eurocarpa...cac380d2shop around. I found some places were giving a year less on the guarantee on the same Battery. and charging more money.try thishttp://www.andrewpag...7/Depot_Detailssee if you have one local and give them a ring, make sure you give your reg.or go on yellowpages, there must local motor factors near you, they tend to be cheaper than big company's near you unless you live out in the sticks. Quote Link to post Share on other sites
jonny__g 1 Posted December 14, 2012 Author Share Posted December 14, 2012 Battery purchased and fitted. will post results of change and hopefully cold starts will be much improved :) Quote Link to post Share on other sites
