Driver Door Quit Working On 1995 Camry Wagon
CADster
one minute it worked fine, the next.. nothing. the key was put intot he lock to unlock the door, but the key only went 1/2 way in. a few jimmies and still nothing. opened the passenger door and reached over to unlock the drivers side and it does nothing. the 'lock tab' flips but the door wont open.
the key will not open the door, the electric lock will not 'unlock' the door (but the lock tab moves). the inside handle will not open the door. the inside handle does not close all the way now either.
im really in a pinch here .. the door is not only locked, but closed.
ive not figured out any way to get the door open to remove the panel to see whats up inside.
any help would be greatly needed :)
It seems like something is jammed inside the door.You could try spraying penetrating fluid into the door lock and hope this frees it up.
296 BUCKS FOR A CAMRY LOCK MECHANISM :ffs:
a plastic roller broke.
what bull**** :censor:
