Mattyb_uk 0 Posted January 3, 2013 Share Posted January 3, 2013 Hi allNew to the forums and a recent Toyota Corolla owner.I've bought a Verso old shape as I believed they were reliable but from doing more research it sounds like there may be problems, particularly with the Oil burning issue.I acquired it with 8 service stamps and 74k on the clock. Oil's little less than halfway on the dipstick but I havent had a chance to properly track it yet.Couple of questions for the groupHow can I tell if it ever had a new short block? I believe Toyota replaced it under warranty and I have no idea how to check.I've read that running it on high octane fuel can help with the deposits in the bores. Has anyone tried this?Is changing Piston Rings / Valve stem Oil seals a job an independent garage could do successfuly?thanks allmatt Quote Link to post Share on other sites
Mattyb_uk 0 Posted January 7, 2013 Author Share Posted January 7, 2013 Hi - No views or replies - so apologies if this is the wrong place to post. I'll repost in the MPV section where it probably belongs!!!-matt Quote Link to post Share on other sites
oldcodger 351 Posted January 7, 2013 Share Posted January 7, 2013 Hi,Cannot answer your question with 100% accuracy, but if I remember what I have read in the forum, the Oil buning issue was cured with models from 2004/5 onwards.No idea if that includes your model though.Either way, you really need to do some miles to see if you have got that problem.Think you have to be using more than 1 ltr of Oil per 1,000 miles before Toyota would even look at it.Unless the Oil looks clean probably worth fitting a new Oil filter and Oil, then check the Oil usage.( assume you are not seeing plumes of smoke from the exhaust)Even if you do have a Oil burning problem that does prove to be in the block I believe, again from what I have read, that Toyota will no longer look at any claims as the age of the engines affected is too great to prove its a manuafacturing defect v fair wear and tear. Quote Link to post Share on other sites
