2007 Corolla Verso T180 - Sat Nav
DTBK
Hey all.
I've just bought a 2007 Corolla Verso T180.
I'd like to get the Sat Nav system for the dash (yes, I know I can have a Tom Tom or phone based system, but I want a system in the dash).
I assume I need to stick with an official Toyota one in order to have the best fit etc.
Naturally though, I expect that going via Toyota would be stupidly expensive.
I can see that some units are available via eBay etc, but how can I check what model system would be compatible? Would any of the TNS510, TNS600 or TNS700 work?
Is this something that I could fit myself or is something best left to a professional to do?
I've seen the installation instructions on Toyota-tech.eu but it seems I need to know what generation my vehicle is... Mine would appear to be either an FMC Gen 2 or an MMC Gen 2 but how can I tell for sure?
I'm sorry for so many questions and hope one of you is able to help.
HI
A friend of mine recently installed a genuine Satnav unit into her Toyota corolla...was a simple straight forward fit using all the existing wiring coming from the car that goes into the stock unit...however you may need a fascia to make it work otherwise it certainly wont look genuine...as for model numbers you'll have to contact Toyota for that or Parks-King on this forum may help you with that...but as far as i know all those model numbers you've listed so far apply to all the new Toyota vehicles which i think start from 08 or 09 upwards...Yours should start with a B...but then i can't say for certain...sorry...but Goodluck matey! :flowers:
Have you found any more information? I bought mine yesterday (exactly the same model but 2006) and trying to get the same thing done.
Thanks,
Lukasz
I ended up picking a kenwood full sat nav system for mine for a lot less than a toyota one.
The problem with the toyota systems is, if you want to update it, you will have to buy the update discs from toyota at £120 per time IIRC!
I got the updates for my kenwood for £30... Plus the sound quality is MUCH better than the oem toyota units could ever provide
