Toyota Corolla Verso Tspirit 2005 - Dvd Monitors Problem
Ali3872
hi
i got corolla verso 2005, working fine so far. today i played dvd and only one monitor switched on when i tried to switch on the first one swithed off and second switched on
so only one monitor work at a time
does anyone know the solution?
  • 5 weeks later...
Just bought the same car on 58 plate, did you get it working? I haven't tested mine yet.
  • 3 months later...
It might be just a bad connection causing your problems, i have had that when someone tall sat in the back and kicked a cable under the passenger seat.
Ant
