Whats The Best Way To Diagnose A Blown Head Gasket ?
tubaman
D4-D T180 79K miles on the clock and fast approaching the 7yr/112K extended warranty
Car going in for a service next moth at a main Toyota dealer (as usual). I want them to test for early stages of Head Gasket failure (no symptoms......yet).
Would you ask them to do a `Sniff Test` ?
How likely would this be to pick up early stages of possible head gasket failure ?
Hi Andy,
I would take it in and get it checked out, sent you a PM mate.
Pete.
first sign i had was the thermostatic fan staying on slighty longer than normal,not muchof a clue but if you know to look for it..........
Just touch wood mate. Your engine may be one of the good ones!
Sniff tests are pretty reliable from what I know. But I must confess; Im no expert.
When I go to buy a car, after the test drive I check the inside of the oil filler cap on the engine. Any white marks means head gasket failure. Thats a pretty standard test but I dont know if its any good at detecting the early stages of a head gasket on its way out.
All the best mate.
