L330wnz 0 Posted January 23, 2013 Share Posted January 23, 2013 As the title says, lift not engaging and have engine management lights on. Just disconnected Battery as I read this can solve the problem. Gonna leave it over night for the ecu to perhaps reset?! Any other ideas or causes? Checked my levels and all was ok, and the Oil looked clean. Please help!!!! Quote Link to post Share on other sites
L330wnz 0 Posted January 23, 2013 Author Share Posted January 23, 2013 I've also read up on the lift bolts and ocv, when lift was engaging it was bouncing the revs at around 7k-ish then the management lights came on so if the bolts were broken it would still allow the revs to go up to the limiter, right? So maybe it's the ocv? Can it be cleaned/checked? I'm a bit of a novice so not wanting to dive in and make it worse. Also the car had only done around 100miles in the last year so lack of use may be the problem?? "/ Quote Link to post Share on other sites
redseven 2 Posted January 23, 2013 Share Posted January 23, 2013 Emailed u back mate Quote Link to post Share on other sites
L330wnz 0 Posted January 23, 2013 Author Share Posted January 23, 2013 Thanks mate, just mailed you back. Quote Link to post Share on other sites
