Heating System Issue - T Sport
JFinney21
Evening all,
Upon driving home tonight after work I've come across and issue with the cars heating system.
I put the temperature up to 'High' (+30) and had the fans on fully. There is some heat coming out of the two vents near the doors but none from the two central vents, although the heat is no way near the temp stated on the display.
After doing some research on the web most people have found the cause to be an air block in the cooling hose due to a whole in the radiator.
Just wanted to find out if any of you guys have ever had this problem or know what I could look at to resolve it.
Cheers,
Josh :)
