Loose Broken Wire Behind The Airfilter
johnro
hello guys
i need your help with smtg. i just realized that i have a loose connector and i don't know what it is.
i found it in between the air filter and the brake fluid bottle
i am attaching some pictures.
i don't know what it is and how important it is for me to fix it. if it is just a sensor or smtg more important
thanks for all your time guys
post-35112-0-80468100-1360256175_thumb.j
post-35112-0-08625800-1360256209_thumb.j
post-35112-0-28938300-1360256271_thumb.j
Just a guess based on its location but I remember when we changed my fuel filter there was an electrical connection on the bottom of it looking a bit sorry for itself. All twisted wires and a bit frayed because the garage hadn't disconnected the connection before unscrewing the filter, hence twisting the wires.
Could be the same for you. Have a look for electrical connections at the bottom of the fuel filter.
ABS sensor?
Some fuel filters have sensor for water collected on the bottom (for warning light).
