Need Info On A/c And Cruise Control Removal On A 91
JoeNoble
Does anybody have any links on how to remove all the A/C equipment and/or the cruise control equipment?
The ac would depend how the belts run if it is ran on a separate belt then its very simple but if it shares a belt with everything else then you would need a shorter belt, that being said some pulleys may not get the right amount of contact easiest way would be a custom setup if the ac runs on the same belt.
Well not sure if it shares a belt with anything else but the previous owner removed its belt or bypassed it so that shouldn't be a problem.
Sadly it sounds as though you are driving a non uk version so my maintenance bookwould be no good, however I believe if you google it there may well be a maintenance guide to download.
Good luck
