cartoonist.ron 0 Posted February 17, 2013 Share Posted February 17, 2013 Hi,Does anyone know how to remove the top of the central console, the bit that houses the sat-nav, or where I could find out?The LEDs in my in-bult satnav failed some while ago and Toyota told me it would cost £2,000 to replace it. However, recently, one of the lights came on again after going over a road bump road, but once I turned off the engine, it didn't come one again. I'm wondering whether the connections at the back may be loose and that is why they've gone out?I did once find a diagram on the web that showed how to do this, but lost it and now can't find it again. Would appreciate someone's guidance.Cheers,Ron Quote Link to post Share on other sites
zulu 2 Posted February 18, 2013 Share Posted February 18, 2013 Hope this helps. Quote Link to post Share on other sites
zulu 2 Posted February 18, 2013 Share Posted February 18, 2013 Just pull that panel towards you and the rest is easy Quote Link to post Share on other sites
cartoonist.ron 0 Posted February 18, 2013 Author Share Posted February 18, 2013 Thanks Zulu. I seem to recall that was in the diagram I saw but I couldn't remember exactly. I take it I edge the trim out nearest to the door and then pull as you suggested? I'm presuming it is therefore clipped in and not screwed.Thanks very much. Quote Link to post Share on other sites
zulu 2 Posted February 18, 2013 Share Posted February 18, 2013 Start from the end and work towards the middle Quote Link to post Share on other sites
cartoonist.ron 0 Posted February 18, 2013 Author Share Posted February 18, 2013 I can't thank you enough mate (I'm in the UK). The sat-nav LEDs have blown and I can replaced the whole unit for one tenth of the cost of a new one (£2,000). However, the dealer would charge me £600 install it! Quote Link to post Share on other sites
