Radio Removal 1999 Avensis
BigH66
Hi, can anyone tell me how to remove the old Toyota cassette player out of my 1999 avensis its the non satnav dash? Thanks Mark.
Hi
Does your console look like this:
http://www.ebay.co.uk/itm/Toyota-Avensis-MK1-97-03-center-console-trim-surround-with-air-blower-vents-026-/281055689504?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AAvensis&hash=item4170397b20
or this:
http://www.ebay.co.uk/itm/Toyota-Avensis-Wood-Effect-Centre-Console-Dashboard-Trim-1997-2000-/130848473898?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e772d432a
If so you will find that the whole unit will come away from the dash. The bottom needs to be eased away first. No wiring needs to be removed as you will be able to 'twist' it out of the way onto the top of the dash (wires are only at the top). The radioa/casette is then fully visible. a philips driver will remove the 4 bolt holding the unit in place.
Thanks very much mate job now complete not as bad as i thought thanks again Gazza :clap:
Hi
http://www.ebay.co.u...=item4170397b20
or this:
http://www.ebay.co.u...=item1e772d432a
job sorted thanks Gazza ; )
