How To Change The Headlight Bulbs In Auris 2.0 D-4D 2007
Norfolk in Chance
Have a look at this Modena's post of 9th March in this topic: http://www.toyotaownersclub.com/forums/topic/78004-xenon-headlight-bulbs/page-2
The first photo identifies which of the plastic fasteners one has to remove.
This should then give access to the rear of the headlight units.
The bulb holders are turned anti-clockwise to remove, and the wiring connector has a lock release that you press to remove. bulbs are a push fit into the bulb holder. Re-fitting is a reversal of the process.
