Transmission Bearing Help Please
SavyM
Hi All
I have had a noise coming from the front of my 2005 Corolla t3 d4d 2ltr diesel which I presumed to be a front wheel bearing.
But under investigation with my brothering law found the the noise was being created from movement where the near side drive shaft enters the gearbox casing.
Which we now know we need to replace the Transmission bearings and seals etc.
The main reason for posting this is that where can you find the parts or part numbers for the bits required I have tried using my searching skills on the web but to no avail.
If anyone out there could help me with this it would be much appreciated.
Many thanks
SavyM (Stacie)
