Indicators Cancelling Early
eygo
does anyone else have this problem with the indicators turning off early for example you are turning right at a roundabout and indicated on approach and as you are starting to make your turn the indicator turns off and you need to put it back on again.
if anyone else has this is there a fix as i am getting ear ache from the other half.
It's normal. a slight movement left or right then begin to straighten up and off goes the signal...
