Rear Brake Pads On 2003 D4D
Glasswarrior
Hi, I need to change the rear brake pads on my 2003 D4D saloon. No stranger to changing pads but I always like to check out the procedure on a car I've never done it on before. I don't have a workshop manual for the car so can anyone let me know if there is anything tricky or are they straightforward? Anyone have a guide or know where I can get one online? They look straightforward but just want to check. Cheers.
This pdf explains all about the braking system on your car.
Pete.
BRAKE.pdf
Nothing tricky when I changed mine. Remember the handbrake shoes are inside the disc - while you're in that far check if they need adjusted up a notch or two.
