Sat Nav, Cigarette Lighter, Radio Fuse/relay
madarega
Where is the internal relay or fuse for the sat nav, cigarette lighter and radio located on my Avensis D4D 2002, please?
Try fuse box behind glove box, fuse 42 is 7.5 amp covers navigation system, multi info display, audio system, power rear view mirror,integration relay, power outlet, gauges and meters. Two rows of fuses end fuse on inner row.
Good Morning Joe,
Firstly, thank You so much for replying. I really do appreciate your input.
Joe, my car is a 2002 Avensis Estate. There does not appear to be a way of removing the glove box, so I can not see if there is a bank of fuses behind or not.
Do You have any further suggestions?
Thank You.
  • 5 years later...
On 4/16/2013 at 10:19 AM, madarega said:
Good Morning Joe,
Thank You.
I know this is an old thread but Google brought me here.
If anyone is having the same problem, removing the glove box, there is a tiny screw to the left of it (on a right-hand driven car), you have to fully open the passenger door to access it.
Just unscrew it and it falls right out.
