Windscreen Washer Jets
Jim13
Hi. The drivers side screen washer jet is partially blocked ( very poor spray compared to passenger side )
Went to remove for cleaning but not wanting to use brute force can't get it out of the bonnet
Suggestions would be most appreciated.
Do NOT try to remove it. It will break.
Instead use a fine sewing needle to poke down the spray holes in the nozzles.
Hi had same problem with mine ( 2010 tourer) got my son to opp screen wash while i held finger over pasenger side jet after a couple of goes it cleared worth a try worked for me
Thanks for your replies folks. Have tried the block one and hopefully the other will clear. No joy. Same with poking with a needle.
Next step is to remove bonnet insulation and see what lies in the tubing. Maybe a filter of some sorts.
Anyone got some clues.
Removed the bonnet sound proofing and found a fancy non return valve. Trying to clean this out was not successful. Replaced this with a T piece and an in-line non return valve. All OK now. You don't want to know what Toyota were asking for a replacement part.
Thanks again for the feed back.
