Affordable Audio Upgrade For Aygo Fire
Manjaser
Hello. I now own an Aygo Fire. I'd like to know how I can make the biggest improvements to the audio quality for the least amount of work. I don't want to have to cut anything. Maybe Speakers that fit right into the space of the current ones in the doors. Maybe an active subwoofer under the seat. Speakers in the rear.
Any advice would be appreciated.
John.
Note: Sorry I should have said, tips on how these should be fitted/wired would be great. If it's a cheap job I could take it to somebody though.
look at my ''audio sorted at last'' thread ........I did have to cut plastic to fit the rear Speakers though.......I did the cutting but the rest was supplied and fitted for under £300 from a local independent mobile audio fitter...... My best advice is to contact a proffessional for advice before you go buying anything....they are the experts and will recommend to suit your needs...........biggest mistake I made is to buy everything first and ask questions later......I bought a head unit that was crap and more expensive than the Sony one I have now....hope that makes sense!
OK I'll do that. Cheers mate.
