nitrous79 0 Posted May 9, 2013 Share Posted May 9, 2013 Hi everyone i am a new owner of a corolla 2004 with the 58807 radio/cd unit i would like to know if this unit has a clock option and if so how can i adjusted. Quote Link to post Share on other sites
Revs 0 Posted May 9, 2013 Share Posted May 9, 2013 I cant recall that it does pal, but there is a clock just a few inches below it that can be adjusted, can you not use that? Quote Link to post Share on other sites
nitrous79 0 Posted May 9, 2013 Author Share Posted May 9, 2013 I cant recall that it does pal, but there is a clock just a few inches below it that can be adjusted, can you not use that?i have the 1.4 terra version with no additional clock and i don't have the manual to see if my radio unit displays the time. Quote Link to post Share on other sites
Revs 0 Posted May 9, 2013 Share Posted May 9, 2013 I cant recall that it does pal, but there is a clock just a few inches below it that can be adjusted, can you not use that?i have the 1.4 terra version with no additional clock and i don't have the manual to see if my radio unit displays the time.I'll take a look in my manual tonight and see if there is a clock function Quote Link to post Share on other sites
nitrous79 0 Posted May 9, 2013 Author Share Posted May 9, 2013 I cant recall that it does pal, but there is a clock just a few inches below it that can be adjusted, can you not use that?i have the 1.4 terra version with no additional clock and i don't have the manual to see if my radio unit displays the time.I'll take a look in my manual tonight and see if there is a clock functionok i'll be waiting thanks mate. Quote Link to post Share on other sites
Revs 0 Posted May 10, 2013 Share Posted May 10, 2013 Ok, took a look in the manual. I'll just copy what it says, i couldn't test it myself as i no longer have the default stock radio in my corolla. My corolla isn't the same model as yours either, but here goes:Push the "ENTER" knob repeatedly until the hour display appears and blinks.To set the hour: turn the knob counter clockwise.To set the minutes: Turn the knob clockwiseTo return to audio mode, leave it for approximately 15 seconds or Push the "TRIP/NAVI" or "AM-FM" button. Quote Link to post Share on other sites
nitrous79 0 Posted May 10, 2013 Author Share Posted May 10, 2013 Ok, took a look in the manual. I'll just copy what it says, i couldn't test it myself as i no longer have the default stock radio in my corolla. My corolla isn't the same model as yours either, but here goes:Push the "ENTER" knob repeatedly until the hour display appears and blinks.To set the hour: turn the knob counter clockwise.To set the minutes: Turn the knob clockwiseTo return to audio mode, leave it for approximately 15 seconds or Push the "TRIP/NAVI" or "AM-FM" button.tried that but no luck i suppose that my radio unit is with no clock option.thanks anyway for your help. Quote Link to post Share on other sites
