Windscreen Misting
eygo
the windscreen misted up quiet badly the other night when we got in the car after getting caught in the rain
there are no leaks in the boot (been fixed) and the front and rear floor pans are dry (checked today)
do the cars just suffer from having a bad ventilation system fitted .
i have given the pollen filter a clean out as it was starting to clog up as this may reduce the air flow entering
the car is there anything else i can check???
Have you checked that the air intake lever is not set to recirculate
To demist efficiently you must have fresh air coming in from outside the car
If you have Aircon it is usefull to have that switched on when demisting
yes its was set to fresh air and we had the aircon on as well
Wet bodies entering a car on a wet day - the combination may have been enough to just prolong the misting up in the car.
yeah very possible frosty just thought i would ask in case there is something i could do to make it better
i could maybe get the aircon checked as it may need re gassing
