Odd Wheel Help Needed,please :)
Filby83
I have the Steelies on my little grey Aygo, 14" Im after the star looking 14" Standard Alloy wheels for it at some point.
However im more interested in weather these are going to weigh less, If they don't il stick with the steelies..
The Steels weigh 11Kg ish with the standard 155 tyre.
If anybody has this weight of the alloys please could you help me out
IIRC my Yaris' 14" alloys weigh ~6kg without the tyres if that's any help!
Standard tyres will probably weigh 5-6kg (I found a 165/60-14 is 13lbs, so a 155 won't be much less).
Make sure you notify your insurance if you change them, as it will invalidate your cover if you don't
