Max Lowering With 195/45/15 Alloys Wheels.
CheatsIP5
I just put 195/45/15 Team Dynamic monza R alloy wheels on my aygo and just wanted to know how much I can lower it without causing any problems. Has anybody put the same size wheels on their aygo and had it lowered? ifso what would you reccomend?
post-132880-0-82548400-1373569894_thumb.
ive got the same wheels and got 35mm lowering springs but its really not that low! even though it does scrape on occasions! but ill be getting coilovers soon and dropping it on the floor! so with 15s you should be able to get pretty low!
As you can tell from the picture there is quite abit of room left in the arches but on full lock its very close to scraping, And at the rear its very close to the petrol filler hose, You had any trouble with that? I was thinking about tte springs but I doubt it will lower it that much, What do you rerkon about 30mm apex lowering kit all round?
