D4D Rav Wont Start
bluebones
hi everyone, bit of a strange one this but we been driving the 2l d4d 04 plate rav with no issues for a while now but today after doing a bit of driving it decided it wont start, it turns over as normal so starter and Battery are fine,there is no eml and was running fine before also oil and water are ok, scv and egr was done a year ago and fuel filter is same again just wondering is there anywhere else i can look before having to take to the garage,
thanks in advance.
george
hi everyone, bit of a strange one this but we been driving the 2l d4d 04 plate rav with no issues for a while now but today after doing a bit of driving it decided it wont start, it turns over as normal so starter and battery are fine,there is no eml and was running fine before also oil and water are ok, scv and egr was done a year ago and fuel filter is same again just wondering is there anywhere else i can look before having to take to the garage,
thanks in advance.
george
check with fuse responsible for booster pump inside the tank.
also -- check with an el contacts for rail pressure sensor.
pay attention of condition of SCV el contacts
by the way -- do you have fuel in the tank :)
regards
thanks in advance.
george
regards
thanks igormus, a merchanic i know( toyota specialist) manage to find the fault, though it was the scv again but after changing for a old set he had spare this wasnt the problem, which ended up to be the denso relay 90987-02027, he only ever come across this problem once before.
happy days :clap:
thanks in advance.
george
regards
happy days :clap:
.......and that relay did or controlled what, George.....? Need input.....
not 100% sure, think he said it powered something for the fuel, but he showed me, he re-fitted the old one the car would not start ,we tryed 3 to 4 times. Then he put the new one in and fired on the key. Was a £53 relay tho.
Problem solved. :driving:
