Sign in to follow this
winelight
O2 / Maf Sensor, Fuel Trim Fault Finding
I have "P0171 Fuel trim too lean (bank 1)".
Inspection of the live data reads:
MAF sensor reading - steady (I believe this means the MAF sensor is probably working OK and does not need cleaning?)
O2 sensor reading - fluctuates between about 0.1V and 0.7V (I believe this is normal operation at idle)?
So, I am stuck to know what to do next?
1. Clean MAF sensor anyway (this seems to be a sensible idea, because it won't cost anything)
2. Replace MAF sensor
3. Replace inlet manifold gasket
4. Replace O2 sensor
5. Replace CAT convertor
6. Something I haven't though of.
Any suggestions please?
Share this post
Link to post
OK, I cleaned the MAF sensor wires with carb cleaner and it solved that problem.
Share this post
Link to post
where abouts is the maf sensor located. ive got a friends aygo with the exact same problem and fault code
Share this post
Link to post
