All Lights On,error Code Of My Avensis (P0400,c1201,c1541,b1660)
damonl
Hi,there. thanks for reading. I've use toyota techstream to check my car, avensis 2011 2.0 D4D. There are some error codes of my car,I don't know what to do with that.
Error Codes:
System DTC
Engine and ECT P0400
ABS/VSC/TRC C1201
EMPS C1541
EPB C1201
SRS airbag B1660
Then, what's wrong with my car? I check some posts, the problem seems to be about EGR. Does that mean I should clear the Egr Valve? Or something else I could do? thanks.
Damon
  • 3 years later...
Hi I have the same problem  and same error and I have a same Toyota avensis 2.0 did 2011.
Did you find any solution  . Please  let  me  know . Thankyou
