Touch And Go Sat Nav
mickandjanet
Hi, once the Sat Nav is set for a destination and started how do you turn it off so that the speed warning also stops.
Regards
Not too sure about the speed warning. To cancel the sat nav route, touch the Options button and select Stop Guidance from the menu.
As far as i know, the speed camera warnings sound regardless of whether a route is set. If you want to stop the beeps, you could try turning the sat nav instruction volume off (I think this would need to be done while a route is set). Not 100% sure if this works but might be worth a go.
From memory, display the map on screen then tap Options > Map Settings >Speed Limits and then pick whatever you want from the options in there. I have mine set to completely off (no cameras shown on map & no warnings)
