1Kd-Ftv Engine Dpf White Smoke
Arjuna
Hi All
I have a Landcruiser LC5 Diesel with 1KD-FTV engine. 8000Miles done. Occasionally I see lot of white smoke blowing with the DPF filter is regenerating on low revs. I am looking for some advice on this:
1. Is this normal? I Doubt actually.
2. I did a service recently. Is the engine oil anything to do with it?
Regards
Nana
i had same problem ive the same landcruiser and toyota sorted it by replacing the copper seal on injecter they were leaking and causing the white smoke
johnny
Thanks for the reply. Is the injector referred the one inside the DPF filter on the silencer?
uotee name="johnsonjohnny4" post="1297843" timestamp="1382826463"]
johnny
