Clock Issue
Olidog
Hi everyone, I've searched this forum and google but I've not found anyone else with this problem before.
I have a 57 plate Aygo and noticed the time was wrong this morning, I changed the time the usual way but since then the dashboard is stuck on that time. Repeated attempts at changing the time yield the same result. Everything else, including the radio still work fine. I note that the colon between the numbers is flashing as if the time won't confirm.
I've tried jabbing all the buttons and shouting at it but its not worked... anyone have any ideas?
I'm no expert - I waited a while to see if someone with the more expertise replied to you (may be someone will soon). It might be worth disconnecting the clock from the Battery for a few minutes - or half an hour or so. I don't know which fuse you'd have to pull - I haven't had a problem with my clock but well - good luck with that!
Thanks, just to let anyone interested... the clock randomly started keeping time again. I'm not sure what happened, at a guess I'd say its was possibly a loose wire somewhere or a problem with the backup Battery in the dashboard (if it has one). Thanks anyway,
Oli
