Please Help With On Board Computer Screen
Reggie83
Hello,
Does anybody know how to fix light in that dark screen with (Range, MPG etc)?
Hi Reggie,
If you able to remove the console then you should end up with this DSCF1256.jpg
The bulbs are not easy to remove and require the de-soldering of the board
If you need further help then I'll be happy to help.
Sorry I don't. Did they fail at the same time or individually? as I'm thinking if they failed simultaneously then the problem may be the bulb driver circuit.
Well they were both off when I bought the car so I don't know if they failed both at the same time or not.
