Exact Fabrication Date
kompressor
To find out exactly when any specific Toyota is made, you will have to ask the dealer,
? - no log book available to check, if buying a car be careful if ones not around to inspect.
Often find when you remove a part like an internal cover or something in the engine bay you will find a label with sub suppliers part no, and date of manufacture.
A couple of those usually give you a good idea of which month of the year the whole car was actually built rather than registered.
