Aftermarket Discs And Pads!
ainsml
i have heard that 3 g discs are very good does anyone know where i can get them form as my disc have started to warp so it a good time to change them.
any other manufacturers that do discs that are any good.
for an ep-91
cheers
Ring Kev at 3G on 01255 880031 very helpful and the disc's are superb!
i have 10 groove discs on mine with braided hose's and uprated pads.
i think the disc's were about £130ish?
marc
You know if you take turns to hard while braking, the grooves will eat away at your brake pads.
i ve the 10groove 3G brakes on my starlet plus a lot of gtturbo's from over here are runnin them and no one has a bad word to say about them!!! plus they are made from Brembo castings so thats a bonus!
Is everyone sure that the centre hole diameter for the starlet sr is 55mm, if so willo order some brakes from 3g. cheers toby
toby if ur unsure take the wheel off and check it with a measurin tape! or ring them and ask.
