E11 Corolla Pre-Facelift To Facelift Front End Conversion
DaveMac
As above lads a lassies, Want to know is it a straight bolt on job with a bit of persuasion or cutting and welding ?
Much help will be appreciated or even a link to a thread where someone has done it :)
I'm no skilled mechanic so I cant be sure of the details. Wings and lower bumper may be bolt on.
But You may find you'll have the most work (hassle) between and including the headlights.
I just did a quick eBay search
"Toyota corolla front panel e11"
And the face lift headlight opening are bigger for the separate main beams.
As long as you have a donor car then its all possible.
as far as i know, it should be a straight swap.. some little crashed e11's converted to zze112 in turkey easily..
you need, bumper, headlamps, front grill, bonnet, side fenders..
front panel (behind the bumper) is the same betweeen them.
