Toyota Corolla T Sport Compressor Advice
Ajwhite7
Hey guys looking at getting a 2005 - 2006 T Sport Compressor with around 60k on the clock? Know of any going primarily trade?and also anything I should be aware of in regard of servicing or parts?
Alex
If you read the forums, quite a few of the guys have had problems replacing the shocks as they tend to leak on this model and TTE don't make them any more so I believe.
Also a lot of people have had problems with the exhaust system collapsing and a lot of people seem to replace them with a custom exhaust. So if your going to check things out check these things.
Also make sure you do an oil check on the supercharger, a phew on inspection have been done dry. If you search the forum on these points you should find some results.
Good luck!
