Automatic Transmission
Maxbonello
I have a toyota ractis/ verso and developed a problem in the transmission.
It revs and won't work.
The mechanic said it have to be replaced and costs loads of money.
Couldn't it be repaired?
Can any one help me please?
Thank you
Although the first generation Ractis wasn't exported to the EU, the second generation was - as the Verso S.
Is your automatic a Multi Mode Transmission or a CVT?
My ractis was first sold to Japan. We bought it to Malta after worked there for a couple of years.
I think it is a CTV.
Thank you
Anyone got any thoughts that this may be an ECU problem?
I know that can cause "harsh changing" so maybe it is not sending instructions to the transmission.
Just a suggestion and if anyone knows better,fire away
Del
I understand that the CVT box uses a transmission oil.......May be worth checking levels or even changing oil
does it give a fault code ????? Let Mr.T read out the ECU for faults
  • 3 years later...
I also having same problem with 2006 MMT model. Planinng to change to CVT model. My one doing only 33 -35 MPG on motorways. Anybody can tell about 1.8 L CVT milage?
Wrong forum - you need to post as a new thread in the Verso club - http://www.toyotaownersclub.com/forums/forum/130-toyota-verso/
