Clutch Failing
Jonny_animator
Hi All,
I have a toyota corolla and it has been making a creaking noise for about 2 months now, today it went to the garage to fix something else and i asked for them to check it and they have said it is a worn clutch but im not sure if that is the case as nothing is failing with the clutch it goes in easy and its not slipping ect....
thanks,
jon
Hello Jonathan - welcome to Toyota Owners Club.
Topic moved to the Corolla club.
Isn't this a known issue and caused by the slave cylinder on the gearbox housing ? I believe some have reported success by giving the cylinder a quick squirt of WD40 (poke the straw through the opening of the protective rubber boot to access it). 30 seconds of a job from opening the bonnet to closing it.
I did give it a squirt with White Greece and it did stop for a little. but started again the next day.
I only squirted under one of the rubber things I'll have to squirt it again under both rubber bits and let you know how it goes.
try it this way
Mod Edit on video to make it easy to see without going off site :thumbsup:
