Drives Side Fog Light Front
David23
Hello to you all.
I have a 59 plate IQ, have just found out the front side, drives Fog Light is broken.
1 , Does anybody have won I could buy.
2 How do you fit them, do you have to take the plastic wheel arch liner out ?
3 Lots on eBay around £28 , are they any good, will they fit OK ?
Kind regards to you all.
David
hi David
I assume when you say its broken, you mean its physically broken. not just the bulb gone
yes you do have to undo the the black lining in the wheel arch. I have not replaced bulbs in this area but a few on here have and removed the front as well. I am sure someone will pick up this post soon
David
Update
Just checked the manual and yes you have to undo the screws holding the cover in the wheel arch. It says to remove the small mud guard at the front .
The fog light fitting is held with mounting lugs and one screw to remove. there is also an an adjustment on the fog lamp so when you replace it you might want to set the new one up the same.
David
Yes Its not a hard job to do, you should be fine, use a wall to line up the new light with the one at the other side
Robert
