Cig Lighter/aux Power Point Fuse
thewingedavenger
I've located the fuse boxes but can't find the fuse for the dash mounted Cig lighter. Is there one or is it a matter of changing the socket. I know some have a fusable connection on them (ie it melts when overheated). Any help greatly appreciated..
I have just ripped mine out to be replaced with a 4 way wired directly to the connector that came of the end of it. I couldn't find out why mine was not working as everything seems intact, even the fusible link wire and there was power through the lead. Mine's a '96 and there is a fuse for it in the footwell fusebox.
