Programming Keyless Entry Remote For Corolla 97
vikash
Hello everyone,
I just got a replacement for my lost keyless entry remote on eBay for my corolla 97. It is a 2 button remote with lock and unlock written on the case. My problem is I am unable to get it work. I have follow the below steps and it works till step 9, but when I press the remote lock button in step 11 nothing happens:
This is the one I got from ebay: http://www.ebay.co.uk/itm/GENUINE-TOYOTA-COROLLA-CARINA-DENSO-1512T-12440-2-BUTTON-REMOTE-ALARM-KEY-FOB-/181398536550?pt=UK_Car_Accessories_Safety_Security&hash=item2a3c320166
Any idea?
1. Get in drivers seat leaving door opened and key NOT in ignition.
2. Insert key into ignition and remove.
3. Press the door lock - unlock button (on door panel switch gear) 5 times (40 secs max).
4. Close drivers door then open it.
5. Press lock - unlock button 5 times again.
6. Insert key into ignition.
7. Turn ign key from 'lock' to 'on' ONCE (no more as you can wipe all codes).
8. Remove key from ign.
9. The central locking should now start locking and unlocking on it's own.
10. Within 20 secs press and hold the remote '
lock' switch for more than 1 second.
11. Once more if the receiver has received the signal the door locks should start operating on own.
12. Close drivers door and open it.
13. Press and hold the '
lock' button on remote for more than 1 second.
14. The door locks should once more cycle lock to unlock on own, once this time.
15. If another transmitter need tuning carry out steps 10- 15 with next transmitter.
