Corolla Compressor 3 Weeks In...
DJTransa
Ok, so having owned the Compressor for 3 weeks now (and loving it) I have only one niggle left to deal with; when touching the accelerator at pretty much any speed, even really lightly, there is a very audible squeak/ping noise which is very high pitched coming from the engine bay. Sounds like a valve or something similar pinging open. Does anyone have any idea what this might be and how to resolve it? Any feedback would be gratefully received. Many thanks!
Sent from my iPad using Toyota OC
Alright mate, this is normal. it is the supercharger engaging.
mine has done it ever since I've had it and I believe they all make this noise.
Must be a noisy supercharger clutch, glad it's normal though! Thanks for your reply. All the best, Tom.
One final question, at what mileage should the supercharger belt be replaced?
Sent from my iPhone using Toyota OC
It's the same belt for all the auxiliary items such as alternator etc.
I would recommend doing every three years but as per all aux belts they do wear.
When changing check your alternator fixings as this is also something that can go wrong on these cars.
Thank you :)
  • 2 years later...
hi there, i have the same problem, which the squeak has got very loud when you press on the accelerator when moving, does anyone have any diagrams to where this supercharger clutch is? or would there be any way to reduce the noise of the squeak with lubricent.
thanks in advance
kingy
