Headrest Removal
pauljj
Can anyone tell me how to remove the headrests on the T27 Avensis,i'm stripping some leather seats down to put on my none electric seat frames,cheers,Paul
This does show you how to remove the headrest at step 2
nice one,i can now see the little push in clip i didn't know was there,thanks
Head rests on a T27 are not designed to be removed ( easily anyway ) as the car is fitted with active headrests which move forwards in the event of a rear impact, there are cables passing up through the post attached to an actuator inside the lower back rest. To remove the headrest you must first unclip the cables from the actuator in the seat.
post-45863-0-63416200-1405798700_thumb.p
i'm starting to think i'll leave it to a pro!
