Toyota Avensis 2.0 D4D 42000 Turbo Making Loud Whistle On Acceleration
borderman
Need some advise the car was quiet till today only bought it from toyota 2 days ago as pre delivery all looked ok even the test drive no issues normal very low whistle like all turbos do which I would class as normal , today I used the car and the pitch on the whistle as got much loader you can here it through exhaust at the back , I done a visual check all the pipes looks ok could the turbo be on its way out .also i noticed the car sounds more erratic sound coming from the engine bay its sounds like a timing chain rattle but i would not think it would be this due to mileage
Could be a leak on the pressurised side, tough to find unless the turbo's providing boost.
