Converting From Distributor To Coil Pack
cherrye10
Hi I got a 1979 Ke50 without an engine. I have a 5a-fe lying around and decided to use it to power it.
The thing is that the dizzy will be at the back when the engine is mounted in a FR position. Is there any way I can convert to coilpack set up, or even MSD(or similar) to do away with the dizzy completely? Don't want to tear holes in the bulkhead.
What are the limitations as to what the stock ecu can handle?
