Gti Oil Rad Hoses
stella
where can u get gti oil hoses that go into the radiator and in to the engine as mine are seeping a little oil,also my oil guage is reading slightly low on pressure,its due 4 a oil change and new filter,could this be a cause?
cheers stella, :thumbsup:
Stella,
If you want second hand ones, your best bet will be fensport.com
I know Demon Tweeks do oil coolers for the GTi, so they will almost certainly do the hoses as well.
The oil pressure gauge could be showing low pressure because there is no oil in the engine. Make sure it's full and then check the pressure again.
Stella,
I know Demon Tweeks do oil coolers for the GTi, so they will almost certainly do the hoses as well. :thumbsup:
