3S-Fse
3S-FSE Corona
Is this engine in any Avensis cars ?
Sent from my iPad using Toyota OC
The 3sfe was an early engine for the Mr2 mkii soon replaced by the 3sge. The uprated engine was also found in the Gen 6 Celica. The pre-facelift mk1 Avensis 2.0 would also have had it (I think). Wikipedia will havea section on the engine no doubt.
The 3S-FE 2 litre engine was in the early Avensis from 1998 - 2000, then replaced by the VVTi engines after. The 3S-FE is not the same as the 3S-FSE since the latter has direct injection. The 1AZ-FSE which replaced the 3S-FE has similar specs the 3S-FSE - both are direct injection, same bore/stroke dimensions and VVTi. Even the power and torque are close. The 3S-FSE has a cambelt.
The 3S-FE is a plain twin cam, belt driven ordinary fuel injected engine with only 126bhp (20+ bhp less).
From my research, it looks like the engine is a cross over between the 3S-FE and the 1AZ-FSE.
With the information above I guess you will have to find another Corona or similar.
