Auto Folding Mirror Kit - Help Needed
TomPL
I have bought on aliexpress a special kit to fold the mirrors automatically while closing the car, and unfolding with the ignition.
The kit was made for Auris 2012, but the connectors looked the same as in my 2013 avensis, so I decided to buy the kit. It is almost plug and play but I need to wire-tap +12V constant (which is not a problem) and (which is a hug problem) something called: door actuator input wire (door lock signal input wire).
Can somebody tell me where can I find the door lock signal input wire, and what is the color of the wire.
Highly appreciated. If you help me I will not hesitate to show the DIY installation!
And yes, when I connect the kit to the mirror connector, all the mirror functions work properly, so I am nearly sure that if I find out where is this door lock input wire, all should work properly
Topic edited to remove 'shouting'.
Please refrain from using all upper case.
  • 2 years later...
Hi Tom,
I was wondering if you actually completed this cause I am interested in replacing my electric mirrors (auris 2008) with electrically folding ones from the facelift model.
The connectors are different so any advise is very welcome.
cheers
