Just Bought An Avensis :)
magicdrshoon
Hi. I've just bought an Avensis saloon, '08, T180 2.2 diesel.
I love it! My favourite car so far!
See you around the forum :)
Hello Chris - welcome to Toyota Owners Club
Hopefully your car will not develop it (or has already had replacement work) but you need to familiarise yourself with http://www.toyotaownersclub.com/forums/index.php?app=core&module=attach&section=attach&attach_id=10987
& look out for the signs.
That doc. is a bit out of date but it's a major (£6K) issue to fix if it does develop & your car may still be inside Toyota's additional goodwill warranty (7 years/112k miles).
Thanks for the heads-up. I am still covered by this until 1/4/2015!
Do you have any idea how wide-spread this problem was? Like 5% or cars, or 20%, 50% ect?
I've only had it for a couple of weeks and so far it's been smooth as silk, but then I haven't had it long enough to witness any oil consumption or any other symptoms.
Cheers.
Only Toyota knows for sure but it's probably under 5% - the problem is you can't tell which until they've already developed it.
One thing to look for is white/pink spotting around the coolant tank from ejected fluid from overpressure.
Did you buy the car privately or from a dealer/trader? Does it have much documentation (so you can check if it has already had work done)?
I bought it from a small-time trader, but professional. I'd happily recommend him! Included a 12 month warranty from VGS I think it was.
I don't remember many receipts in the document pack but I'll check tomorrow. It has a nearly full Toyota service history (one interim missing and one service from an independent). I've just had it serviced by Toyota in St. Albans.
Thanks for your help! :)
