Weights ?
R14LYX
Looking at buying a t sport to build into a rally car and there is one local to me but its a 5 door .. Is there much weight difference between a 3 and 5 ?
Looking at the May 2006 brochure the kerb weight of the 3 door is 1315kg and the 5 door 1350kg
I would not have a 5 door as a rally car, too much flex in the car, better with a 3 door
That's not a lot of difference once the electric window motors is out and all the doors stripped it won't be much heavier guessing everything else is the same ?
How do you work that out ? The side pillars will be stronger and once it's properly caged it should have hardly any flex anyway ?? In my head anyway haha
Thanks for the input so far !
